Forums >> Revit Building >> Technical Support >> Changing global elevation??
Tue, Feb 17, 2009 at 11:57:48 AM | Changing global elevation??
masterbrewer
This is my first post, so please be kind :-)  I started a project and put my Level 1 at 0'-0".  Now I want to go back and change Level 1 to read 100'-0" at the request of our Structural Engineer.  Any ideas on a way to do this?  I thought about constraining the distance on my existing levels and changing the elevations, but then my detailing doesn' t move with the levels.  Thanks in advance!  FYI, I'm using Revit Architecture 2009.
Tue, Feb 17, 2009 at 12:06:41 PM | Changing global elevation??
masterbrewer
Sorry for the question - I just found another post with the solution.  I'll try and research the answer more before I post :-)
changing base line elevation
Fri, Jul 25, 2008 at 2:28:46 PM
Global Changes to Bldg Grids in elevations.
Thu, May 27, 2004 at 8:16:05 PM
Changing Elevation Parent View
Tue, Nov 9, 2010 at 4:35:05 PM
updating/changing elevation tag types
Wed, Mar 19, 2008 at 9:49:46 AM
Revit Structure 2008 and NVIDA card settings?
Thu, May 1, 2008 at 4:13:11 AM
Page generation time: 0.4819
