Forums >> Revit Systems >> Technical Support >> Extruded roof - surface pattern displaying incorrect
Tue, Feb 17, 2009 at 11:46:30 AM | Extruded roof - surface pattern displaying incorrect
mustarddesign
I have created a simple barrel tile extruded roof.  When I copy or mirror the extruded roof to create one exactly like on the other side of my house the surface pattern rotates 180 degrees.  The roof is still built correctly, just the surface pattern rotates 180 degrees.  Any suggestions on why this happens and how to correct it.  Thank you.
Tue, Feb 17, 2009 at 12:44:43 PM | Extruded roof - surface pattern displaying incorrect
4 Stars: 205 Votes
Strange, what version are you working???
Tue, Feb 17, 2009 at 1:12:04 PM | Extruded roof - surface pattern displaying incorrect
mustarddesign
Revit 9.1.  I have never had this happen before, and am unsure what to do about it.  I have even deleted the roof and built it again, and still havethe same problem when I mirro or copy it.
Tue, Feb 17, 2009 at 1:17:46 PM | Extruded roof - surface pattern displaying incorrect
4 Stars: 205 Votes
I don't work with that version about almost 2 years, maybe anyone can help????
It's time to Upgrade...
Wed, Feb 18, 2009 at 6:12:08 AM | Extruded roof - surface pattern displaying incorrect
caduk
personally i have never worked with that version or much architectural at all, but off my head it would sound like the workplane could be the culprit. sorry if its noob input but its better to suggest than not at all!
Wed, Sep 8, 2010 at 8:52:26 AM | Extruded roof - surface pattern displaying incorrect
leothelionator
You should be able to treat the surface pattern just like a tile wall or brick wall and edit the pattern directly on the drawing.  Click on the object and hit TAB until it takes you to the surface pattern lines, then adjust them as needed by shifting and rotating.
Wed, Sep 8, 2010 at 10:00:11 AM | Extruded roof - surface pattern displaying incorrect
The fix is not to mirror the roof, mirror the sketch.  Revit does not mirror some things very well.
>>> Better yet -  If extruded, edit the roof you have and edit / mirror that sketch in that roof session.
Edited on: Wed, Sep 8, 2010 at 10:01:24 AM
Stair Surface Pattern Not Displaying
Wed, Sep 8, 2010 at 10:05:09 AM
Surface pattern problem
Tue, May 18, 2010 at 9:15:56 AM
Surface Pattern Wrap Roof Question
Tue, Nov 12, 2013 at 5:24:44 PM
Revit 2015, Conical Roof Surface Pattern Twist
Wed, Apr 22, 2015 at 8:57:44 AM
problems with metal roof surface pattern
Tue, Mar 10, 2009 at 2:02:45 AM
Page generation time: 2.4309
