Forums >> Revit Building >> Technical Support >> Smoothing contours...
Mon, Feb 16, 2009 at 5:17:43 PM | Smoothing contours...
atkinsonhall
(Revit Arch 2009)
I creted a topo surface using points located on top of an imported survey. It worked fine, except that the contours are straight line segments making for a very jagged looking site. Is there any way to get it to smooth out the contours (curves and rounded corners)??? thanks,
Tue, Feb 17, 2009 at 7:13:56 AM | Smoothing contours...
 If you have four points in a square, the contour will be a square.  Add more points along the contours and the Revit topo will adjust.
Tue, Feb 17, 2009 at 8:33:56 AM | Smoothing contours...
atkinsonhall
so i guess there is no such feature?
if from a survey a road is defined by 3 points (one on each side and one at the crown) you will end up with arrow heads pointing up hill..... (in reality it would be smooth arcs). it would be a pain to have to manually figure out enough of the in-between points to smooth it out.
Tue, Feb 17, 2009 at 8:43:14 AM | Smoothing contours...
KingRevit
4 Stars: 12 Votes
yes revit isn't really the tool for this, civil 3d or similar is better for this
Revit Topo to Max... Smoothing...
Thu, Jan 21, 2010 at 8:13:38 AM
Font smoothing option
Wed, Jan 26, 2011 at 1:33:09 PM
contours
Mon, Apr 24, 2006 at 5:16:04 AM
New vs. Existing Contours [ 1 2 ]
Thu, Jun 28, 2012 at 2:27:20 PM
16
Topo surface Control from imported contours
Mon, Feb 17, 2014 at 7:28:49 AM
Page generation time: 0.1167
