Forums >> Revit Structure >> Technical Support >> x brace frame
Mon, Feb 16, 2009 at 2:21:58 PM | x brace frame
hhwse
I have a project that has “x” brace frames.  One brace will be continuous and the other will weld to a gusset plate at the mid-point of the first brace.  How do I create this?  I can make intersecting braces but can not break the second brace at the mid-point of the first.
Tue, Feb 17, 2009 at 6:11:43 AM | x brace frame
gentyche
im not sure if this is what u want to achieve...but here goes...
maybe you could create three instances of the brace...one long and two small pieces...
Tue, Feb 17, 2009 at 8:22:37 AM | x brace frame
hhwse
That is what I was trying to create but couldn't get it to work. The analytical model kept messing it up.  How did you do it?
Tue, Feb 17, 2009 at 12:34:25 PM | x brace frame
sheartab
Are you looking for something like this?
Tue, Feb 17, 2009 at 3:52:19 PM | x brace frame
hhwse
I am trying to create a single story x-brace like what gentyche has shown.  The two-story x-brace as shown by sheartab is easy in Revit but I haven't figured out the single story.
Tue, Feb 17, 2009 at 6:29:19 PM | x brace frame
Hellfish13
3 Stars: 2 Votes
Have you tried the coping tool? Works for me on x-braces Smile
Tue, Feb 17, 2009 at 7:03:33 PM | x brace frame
hhwse
The problem i am having is how do you break the intersecting brace at the continnuous brace?
Wed, Dec 23, 2009 at 1:39:55 PM | x brace frame
pdoug
3 Stars: 2 Votes
What I would do:
Place a framing elevation (while in plan view) on the grid you want to model the braced frame.Activate the new frame elevation.
Draw reference plane at the center of the beam vertically and horizontally and extend each past the workpoints. (I realize this is an extra step, but I like to be sure)
Draw a continuous brace from low workpoint on one side to the high workpoint on the other.
Draw a second brace from opposite low workpoint to the center of cont brace. Then draw a brace from the center of the cont brace to the opposite high workpoint.
I just did it and it worked like a charm...
Brace that goes through a girt. Best way to break the brace?
Fri, May 10, 2013 at 11:29:35 AM
Connection Points
Mon, Apr 13, 2015 at 11:02:16 AM
View Range with Brace Frames
Wed, Dec 23, 2009 at 12:00:51 PM
X-brace in plan view help (new)
Mon, Jul 13, 2009 at 1:39:14 PM
vertical brace center line
Mon, Jun 4, 2007 at 3:38:32 PM
Page generation time: 0.0488
