Forums >> Revit Building >> Technical Support >> can't adjust roof overhang
Mon, Feb 16, 2009 at 11:25:33 AM | can't adjust roof overhang
vanderloo
Can anyone tell me why I am unable to adjust my roof overhang. I created a new family type from "generic 12" only to change thickness to 4". When I select any perimeter line, the overhang box is greyed out. Surprised there is nothing for overhang in Roof properties.Thanks,Phil
Mon, Feb 16, 2009 at 11:42:47 AM | can't adjust roof overhang
When you create a roof by footprint, the overhang is defined on your options bar - not in the type.
Mon, Feb 16, 2009 at 11:58:38 AM | can't adjust roof overhang
tim123
4 Stars: 19 Votes
Also, if you manually draw the roofline it is not recognised as an overhang.  If the roof is drawn using the 'pick walls' tool then you will have option of adjusting the overhang.
Mon, Feb 16, 2009 at 12:12:59 PM | can't adjust roof overhang
vanderloo
Thank You. We shouldn't be working today. Lincoln would be pissed!
Gutter problems...
Thu, Jul 6, 2006 at 11:48:10 PM
Roof Overhang extension
Fri, Feb 3, 2017 at 8:20:07 PM
Roof overhang without 'picking a wall'
Thu, Nov 20, 2008 at 8:03:16 AM
unable to add roof overhang
Tue, Mar 8, 2011 at 1:15:32 PM
Flat roof Overhang with profile
Tue, Apr 13, 2010 at 9:59:56 AM
Page generation time: 4.9773
