Forums >> Revit Building >> Technical Support >> Rotating the text in dimensions
Mon, Feb 16, 2009 at 11:16:00 AM | Rotating the text in dimensions
cheryla
3 Stars: 2 Votes
Is there a way to override the text in dimensions so I can rotate just the text? I have a rotated viewport on a few sheets. I have already rotated the other text in the view, but there is no "keep readable" button to override in the dimensions... help!
Cheryl Nelson
Randall W. Hein Architects
Mon, Feb 16, 2009 at 11:38:15 AM | Rotating the text in dimensions
Look at your text setup options under settings/annotations/dimensions
Mon, Feb 16, 2009 at 11:41:43 AM | Rotating the text in dimensions
cheryla
3 Stars: 2 Votes
Ok.... I did... still nothing that will essentially let me place text upside down in a view, but that will look correct on the sheet. The only options are up left, up right, right up, and left up.... I guess I need an option that says down.
Cheryl Nelson
Mon, Feb 16, 2009 at 11:46:24 AM | Rotating the text in dimensions
I don't understand.  Revit automatically will rotate dimensions when you rotate a view to place it on a sheet.  Did you rotate your sheet instead?  If so - don't do that.
Mon, Feb 16, 2009 at 11:49:52 AM | Rotating the text in dimensions
cheryla
3 Stars: 2 Votes
No I rotated the viewport, not the sheet itself. The viewport is rotated 90 deg. counter clockwise to fit on the sheet better. When I do that the text in some dimensions looks like its upside down. I need to rotate the text, but Revit is fighting it.
Cheryl Nelson
Mon, Feb 16, 2009 at 11:58:04 AM | Rotating the text in dimensions
You activated the view - picked the crop window and rotated that?  Correct?
Mon, Feb 16, 2009 at 12:00:04 PM | Rotating the text in dimensions
cheryla
3 Stars: 2 Votes
No. I placed the view on the sheet. Selected the vieport, and in the properties of that viewport, I picked rotate counterclockwise 90 deg.
Cheryl Nelson
Mon, Feb 16, 2009 at 4:27:20 PM | Rotating the text in dimensions
Try the method I described....
Tue, Feb 17, 2009 at 12:18:16 PM | Rotating the text in dimensions
cheryla
3 Stars: 2 Votes
Sorry for my ignorance, and thank you for your patience.. I got it.
Cheryl Nelson
Adding Text Below Dimensions
Sat, Mar 3, 2007 at 10:55:04 AM
11
Rotating Family Text
Wed, May 7, 2014 at 5:04:06 PM
View Rotation - Dimension text
Thu, Jul 21, 2016 at 12:06:48 AM
Text width for dimensions...
Tue, Aug 7, 2007 at 7:55:42 AM
TEXT AND DIMENSIONS
Tue, Sep 28, 2004 at 12:49:38 AM
Page generation time: 1.6562
