Forums >> Revit Building >> Technical Support >> Rendering function greyed out in Revit Arch 2009
Sun, Feb 15, 2009 at 11:21:09 PM | Rendering function greyed out in Revit Arch 2009
Cassie
My upgrade from Revit Arch 2008 to Revit Arch 2009 cause the new installation rendering function to be greyed out . I did choose the rendering function to install from the disk configure option . Am I missing someting because not even the little green pot display in the bottom row of icons ?.
The correct path was also used -c:\Program Files\Revit Architecture 2009\Data\Rendering\assetlibrary_base.fbx
Could some one please help me correct this problem as the program is useless for me without the rendering function .
Thank you
Mon, Feb 16, 2009 at 4:53:18 AM | Rendering function greyed out in Revit Arch 2009
tim123
4 Stars: 19 Votes
Hi Cassie
In the options dialogue under tools, do you have the correct path to your rendering files?
Rendering in Revit Structure 2009?
Sat, Dec 24, 2016 at 5:11:53 AM
render dialog tool greyed out
Sat, Mar 21, 2009 at 4:00:44 PM
Problem Rendering Sketch-up Components in Revit Arch 2009
Tue, Dec 9, 2008 at 1:08:36 PM
Revit MEP 2009 Rendering
Thu, Mar 5, 2009 at 8:35:55 PM
Rendering in Revit 2009 [ 1 2 ]
Thu, Dec 31, 2009 at 10:41:31 AM
19
Page generation time: 4.0406
