Forums >> Revit Structure >> Technical Support >> Newbie Question
Fri, Feb 13, 2009 at 4:53:29 PM | Newbie Question
TONY121
Being new to revit I have noticed that there are a lot of families dedicated to concrete and steel. This is great for my company but we also do a lot of projects with timber and specifically timber stud walls. If I am working on a project which uses timber walls how do I represent this on the plan sheets? Also, How do I identify shear walls, with a symbol, other then changing the element properties. The previous question also applies to bearing walls?
Sat, Feb 14, 2009 at 7:25:30 AM | Newbie Question
The first thing you should learn as a newbie is that there is a lot of information here on RevitCITY if you look for it.  You should use simple one worh serches in the forum and sometimes you will have to use a synonym for your word.  Be a little creative in the word you use.
In your case the word should simple be "stud" .   Hit the search tab - change the search area to forum and enter your word.  You will find a lot of different posts on this subject from a lot of talented users.
Extruded roof - fascia - (Newbie question)
Wed, Jul 5, 2017 at 8:12:43 PM
13
Newbie Grid Question Revit 2008
Tue, May 15, 2007 at 1:48:03 PM
Having problems with my Project Browser, a newbie question
Mon, May 2, 2011 at 12:38:33 AM
newbie..
Sun, Nov 28, 2010 at 2:33:02 AM
Newbie here...quick siding question
Sun, Feb 17, 2008 at 3:24:25 AM
Page generation time: 3.7618
