Forums >> Revit Building >> Technical Support >> Interior Elevations appear transparent
Fri, Feb 13, 2009 at 4:53:12 PM | Interior Elevations appear transparent
amr9246
For some reason everytime I place an interior elevation it shows as partially wireframe (not showing every detail, just the immediate wall behind the wall I am looking at.  Ive checked a thousand times and its set to hidden line.  Anny ideas on how to fix this?
Sat, Feb 14, 2009 at 10:53:12 PM | Interior Elevations appear transparent
qthdad
5 Stars: 2 Votes
What flavor and version of Revit are you using?
Do you have linked files?
Mon, Feb 16, 2009 at 9:40:42 PM | Interior Elevations appear transparent
shaun_kiwi
5 Stars: 2 Votes
Phase overide?
Shaun
Tue, Feb 17, 2009 at 11:24:23 AM | Interior Elevations appear transparent
amr9246
I am using Revit Architecture 2009.  I do not have any phases as of yet and there are no graphic overrides.
Thanks!
Tue, Feb 17, 2009 at 1:44:04 PM | Interior Elevations appear transparent
shaun_kiwi
5 Stars: 2 Votes
Where is the cutting plane?
Wall construction?
There are phases in use by default and a phase override have you gotten rid of these?
Shaun
Tue, Feb 17, 2009 at 2:22:17 PM | Interior Elevations appear transparent
amr9246
Cutting plane is through the middle of the room, wall construction is solid, 2x4 wood stud w/ gyp both sides.  All phases are showing, (default phases)
thanks again
elevations have gone transparent
Wed, Jun 6, 2012 at 6:02:04 PM
Problem with Interior elevations
Fri, Feb 13, 2015 at 1:51:29 PM
interior elevations
Wed, Apr 11, 2007 at 9:43:04 AM
Interior Elevations Referencing Detail Numbers
Sat, Oct 13, 2007 at 11:04:39 AM
Interior Elevations
Mon, Jan 23, 2006 at 5:42:42 AM
Page generation time: 2.0499
