Forums >> Revit Building >> Technical Support >> Can linked RVTs NOT be selected?
Fri, Feb 13, 2009 at 9:36:15 AM | Can linked RVTs NOT be selected?
BVHis
BVHis Avatar
I know you can pin a linked RVT to restrict it's movement, but can you set it up so that you can still see it, but it doesn't highlight if you accidentally select it?
  Matt W
Fri, Feb 13, 2009 at 9:43:15 AM | Can linked RVTs NOT be selected?
With Revit, you really have to pay attention to window and crossing selections.  Given dpth of view, you may be picking something on the otherside of the wall you can see through.  Always use your filter when selecting!
Fri, Feb 13, 2009 at 9:45:19 AM | Can linked RVTs NOT be selected?
BVHis
BVHis Avatar
So basically that's a big, fat NO.  Which is pretty much what I was expecting - I just wanted to double-check.
Thanks.
Fri, Feb 13, 2009 at 9:51:16 AM | Can linked RVTs NOT be selected?
I think this just goes along with developing good REVIT habits.   Looking at your filter after selecting with windows or crossing is a MUST ... with individual selections, you always want to use your tab and see what you are selecting in the lower left corner.
Fri, Feb 13, 2009 at 9:57:27 AM | Can linked RVTs NOT be selected?
BVHis
BVHis Avatar
I'm at the beginning of the "learning stage" with MEP, so now's the time to develop those good habits! Winking
Thanks!
Can't select the linked model
Mon, Aug 4, 2014 at 1:06:26 PM
Aligned to selected levels.
Sun, Jul 17, 2016 at 4:49:50 PM
13
Unable to PICK lines from linked file
Thu, Aug 21, 2014 at 8:47:06 AM
Model lines in LINKED files
Fri, Jul 19, 2013 at 9:48:35 AM
Refreshing linked AutoCad drawings
Fri, Jan 30, 2009 at 11:48:50 AM
Page generation time: 1.4769
