16 Users Online (14 Members):
Forums >> Revit Structure >> Technical Support >> Revit STRUCTURE
9 Posts No Rating |
Hello my fellow Reviteers,
I wonder if anyone of you has any new information about REVIT STRUCTURE SYSTEM 8. I am looking for an evaluaton copy or a demo copy. I have REVIT 7 and I think both Revit 7 and REVIT STRUCTURE SYSTEM 8 will make a perfect tool.
If any one can help me please advise...
Thanks a million...
Revit structure been released only in the US for now, the problen is that every country is different and they need to change the program to suite.
and it will work with Revit 8 not 7, you won't be able to open in 7...
9 Posts No Rating |
Thanks for your reply. I think they can solve the problem by applying differnet building codes that will suit each country. I will try to get revit building 8 in order to be prepared. Thanks
It is only released in US? Surely hope it can be released to Asia soon..
btw, any good links to Revit Structure on-line tutorials?
To Admin: As Revit Structure and properly future Revit MEP is on-coming, properly we need to restructure the technical forum to to sub-forums to avoid confusions?
What do you all think??
----------------------------------- Life is never easy but nor it should be complex. Just stay simple  |
9 Posts No Rating |
I would like to see some tutorials soon online in order to evaluate it.
If you contact autodesk and make known your interest they may be able to supply you with a demo copy "of course it will be setup for the US" but it may give you an idea.
9 Posts No Rating |
Thanks for the advise Mr Spot.. I will try to contact Autodesk
Metalic Structure in Revit Architecture |
Fri, Dec 3, 2010 at 1:10:10 PM
Modyfing columns in Revit Structure |
Thu, Nov 1, 2007 at 12:55:53 PM
Hello All! Moving Revit Arch Drawing to Revit Structure Problems |
Thu, Feb 12, 2009 at 8:18:59 AM
Need HELP!! Geting a Navisworks file inn to Revit Structure |
Mon, Apr 8, 2013 at 8:02:00 AM
SketchUp into Revit Structure 2009 |
Fri, Feb 27, 2009 at 9:51:24 AM
