Forums >> Revit Building >> Technical Support >> scheduling walls per level
Thu, Feb 12, 2009 at 12:35:48 PM | scheduling walls per level
billyjencks
Why isn't "level" a possible field in wall schedules?? Is there a way to sort a wall schedule by host levels?
Really I'm just trying to select ALL walls of a specific type on a single level. What's the best way to do this?
Cheers
Thu, Feb 12, 2009 at 1:19:14 PM | scheduling walls per level
afc4
3 Stars: 3 Votes
You cant schedule legends by level as you can with furniture,doors or windows but you could add a parameter to a wall that would allow you to add which level it is on. it will take some work and it would all be a manual entry but it will allow you to sort by level.
Walls show up on Second Level plan
Wed, Dec 19, 2018 at 8:39:24 AM
scheduling windows and curtain walls together
Wed, May 11, 2011 at 7:52:31 AM
2019 scheduling rooms from linked model using level from main model
Wed, Dec 11, 2019 at 2:55:46 PM
Scheduling Walls
Sat, Feb 23, 2008 at 11:47:26 AM
SCHEDULING CURTAIN WALLS
Wed, Jan 11, 2006 at 3:50:30 PM
Page generation time: 0.7994
