Forums >> Revit Building >> Technical Support >> signage text
Thu, Feb 12, 2009 at 9:02:32 AM | signage text
phx2gfk
trying to create some signage plaques in a legend.  when using text (i.e. mens restroom, elevator, etc...), it scales up and down with the scale of the drawing and i need it to stay the same size.  any way around this?  i tried creating a family and using model text but it becomes distorted due to the text size  3/4".
thanks
Edited on: Thu, Feb 12, 2009 at 9:45:39 AM
Thu, Feb 12, 2009 at 2:05:02 PM | signage text
Revit does not like very small items so if you are using 3/4" model text in a 1/4 scale view - it probably will not work and may not work in renders.
Use a jpeg instead if you want it to work in rendered views.
3D text to be used as Signage
Tue, Jan 23, 2007 at 6:52:24 AM
Attaching Signage to pannels??
Thu, Aug 10, 2006 at 12:45:22 AM
extruded text
Thu, May 5, 2005 at 5:59:28 PM
how to i create an office signage for an interior space
Mon, Jun 20, 2005 at 5:07:20 AM
Best ada signage and custom wall plaques.
Fri, Oct 28, 2016 at 4:12:07 AM
Page generation time: 1.4398
