Forums >> Revit Building >> Technical Support >> making labels editable
Wed, Feb 11, 2009 at 8:11:36 PM | making labels editable
vanderloo
I'm crerating a custom titlle block and can't seem to figure out how to create an editable label. See attachment below. Client Name and Project name were already in the file, (and editable). I've added project address and am unable to edit in project.
Thanks, Phil
Thu, Feb 12, 2009 at 6:07:40 AM | making labels editable
puzzle
4 Stars: 10 Votes
the project address can be edited under Settings/project Information/Project Address
Macca
Sunshine Coast
QLD Australia
Thu, Feb 12, 2009 at 12:16:28 PM | making labels editable
quinn
Title blocks require shared parameters if you are going to make your own label category.
Make a shared parameter set as a text , type parameter.
Add label to your title block, check the little folder at the bottom of the parameters list when the window pops up add a new shared parameter.  Once loaded you will see it in the label list so add it to your label.  Save title block.
Load title block into project - go to settings - project parameters - shared parameters find text file you made , then select title block family in the list of family types you are required to select from.  Should appear as a blue question mark in title block in the project so you can enter text.
Hope this helps
Thu, Feb 12, 2009 at 1:12:46 PM | making labels editable
vanderloo
Thanks All. That's what I needed.
Cant make editable labels in a title block.
Fri, Aug 7, 2020 at 1:11:01 AM
Creating Editable Labels
Tue, Sep 1, 2020 at 7:05:46 PM
Titleblock issues: Can't 'activate' the labels I created...
Mon, Jan 24, 2011 at 3:49:27 PM
Labels in Titleblocks?
Mon, Nov 10, 2008 at 3:30:01 PM
Titleblock Labels (Custom to each sheet) [ 1 2 ]
Mon, Oct 5, 2015 at 2:46:21 PM
21
Page generation time: 1.6379
