Forums >> Revit Building >> Technical Support >> showing lintels
Wed, Feb 11, 2009 at 4:14:13 PM | showing lintels
jcrowe
I have an exiting building I am trying to model, with different exterior sill and lintel conditions for which I am trying to create toggles in the window families to avoid mutiple families of the same basic window.  One type of lintel is a steel c-channel with the flanges facing out and recessed into a pocket above the window, but not cutting all the way through the wall.  I have created families of the lintels inserted in a wall with a void form so they show properly, and then inserted them into the window family.  They model great in the window family but will not show properly when loaded into the Model.  I am about to pull my hair out because it won't work. Any suggestions?
LINTELS
Tue, Sep 11, 2007 at 12:52:11 PM
Lintels in Revit Structure
Mon, Nov 5, 2007 at 10:31:29 AM
masonry lintels
Thu, Jun 12, 2008 at 12:58:13 PM
How to create masonry or concrete lintels and display them correctly?
Fri, Apr 9, 2010 at 3:42:59 PM
Overhead Lintel - Doors and Windows
Wed, Mar 22, 2006 at 4:23:48 PM
Page generation time: 0.1311
