Forums >> General Discussion >> Revit Project Management >> Parametric travelator/escalator?
Wed, Feb 11, 2009 at 4:12:51 PM | Parametric travelator/escalator?
doretheo
Anyone know of a parametric travelator and/or escalator model that can be edited numerically for height etc?
thnx
Wed, Feb 11, 2009 at 5:02:41 PM | Parametric travelator/escalator?
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
A creative person might make this out of stairs so it can be associated to floors. Makes height adjustments a lot easier.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Wed, Jun 10, 2009 at 1:29:37 PM | Parametric travelator/escalator?
loistl
Our fully parameterized Escalator Revit® Family has been released and is available for download at http://www.revit-content.com/content/00-01-5514061-Escalator.htm 30 flexible ParameterYou have 30 possibilities to setup your Escalator to every available Escalator. With just one Family you have thousands of possibilities to get exactly the Escalator you need for your Project.Choose your AngleOne of this 30 Parameters is the Angle of the Run. The Family is fully parametrised - that means that you just need to change the Parameter for the Angle for example to 30° or 35° (or every angle you would like) and you have automatically your Escalator (even the Steps adjust automatically accordingly to the Angle, Height of Level, etc.)You want to see always a correct Floor Plan ?No Problem at all - This fully parametrised Escalator Family shows the Model corect cutted and even the hidden Lines for the Model above thecutting Line is fully parametrised.
Fri, Jan 3, 2014 at 6:14:06 AM | Parametric travelator/escalator?
amolese
Does this do a curved escalator?
Fri, Jan 3, 2014 at 7:28:03 AM | Parametric travelator/escalator?
It will not.
Fri, Jan 3, 2014 at 8:48:14 AM | Parametric travelator/escalator?
amolese
Where do I get one that does?
Fri, Jan 3, 2014 at 8:50:05 AM | Parametric travelator/escalator?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You will most likely have to make one yourself unless you can do a google search and find one somewhere.
Fri, Jan 3, 2014 at 11:29:47 AM | Parametric travelator/escalator?
amolese
Can someone give me an outline description of how to make one myself?
Fri, Jan 3, 2014 at 11:33:50 AM | Parametric travelator/escalator?
Use stairs and walls.
Sun, Jan 24, 2016 at 7:54:11 PM | Parametric travelator/escalator?
mneglia
I just made a really simple video on how to make an escalator from scratch on my channel. It's parametric, and you can set any height that you need. I hope this helps!
https://www.youtube.com/watch?v=1kVPrkJ766Q
Revit blog: www.bimeveryday.com
Escalator
Mon, Jan 9, 2012 at 4:14:51 PM
11
Editing height of escalator?
Fri, Mar 6, 2009 at 5:28:40 PM
parameter change
Sat, May 9, 2009 at 1:43:20 PM
Parametric Arrays
Fri, Feb 5, 2010 at 3:19:22 AM
Families' View Range
Thu, Jan 21, 2010 at 8:43:29 AM
Page generation time: 0.2827
