Forums >> Revit Building >> Technical Support >> Scheduling Issues - rounding up
Wed, Feb 11, 2009 at 3:28:19 PM | Scheduling Issues - rounding up
bradleymatthew
I have generated a schedule to determine the quantity of different items from their length.  For instance: a countertop can only come in 8' lengths - for sake of argument - and I have many different lengths and modeled quantities.  I tried simply creating a calculated formula that adds all lengths and divides by 8', but it's not accurate and won't round up.  I tried using the +.4999 on the end (so the formula is now: Length/8' +.499), but that really threw the counts off because of the number of small counters I have (my best guess is that it was adding the .499 to each object, cause my counts to nearly double).
What am i doing wrong.  I need to create this similar type of schedule for several other things and it has to be accurate - if not dead-on, then over by 1....never ever under.
Bradley
Wed, Feb 11, 2009 at 8:11:30 PM | Scheduling Issues - rounding up
qthdad
5 Stars: 2 Votes
You would probably need to be creative since there are only limited functions available in Revit for formula.
Here's one method that came to mind.
Create three PARAMETERS:
Actual_Length as Length
Length_Rounded_Up as Length
B as Integer
B = Actual_Length / 1'
Length_Rounded_Up = IF(B * 1' < Actual_Length, B * 1' + 1', B * 1')
Edited on: Wed, Feb 11, 2009 at 8:18:26 PMEdited on: Wed, Feb 11, 2009 at 8:18:51 PMEdited on: Wed, Feb 11, 2009 at 8:19:18 PM
Edited on: Wed, Feb 11, 2009 at 8:19:54 PM
Thu, Feb 12, 2009 at 10:57:05 AM | Scheduling Issues - rounding up
bradleymatthew
qthdad - what I'm really looking for is a quantity of the 8' counters.  I like your idea of creating a paramater that generates length as an integer - that at least lets me know what I'm working with, but it all goes funky when I start to generate quantities within the schedule.
I really could make this work if I could simply take the overall sum of the length of all counters and divide that by the 8' to get me a total quantity of counters, but Revit won't let me.....what am I missing?
Bradley
Thu, Feb 12, 2009 at 12:37:56 PM | Scheduling Issues - rounding up
qthdad
5 Stars: 2 Votes
You don't need to adding .499 to each object. That's probably what's throwing your numbers out of whack. You can probably take the "trick" I did and use it in a calculated field within the schedule that is based on the objects' actual length.
Thu, Feb 12, 2009 at 4:39:59 PM | Scheduling Issues - rounding up
bradleymatthew
Sorry for the double reply....OK - I got it to calculate accurately.  I want to be able to tell it to add 1 object if the total count < 1.  I tried setting up another calculated value that would use this formula:  Quantity + if(Quantity<1, 1, 0) + if(Quantity =1, 1, 0)  .  The problem here is that it is adding 1 to the individual objects that are less than one, rather than adding 1 onto the sum of all objects...does that make sense?
Bradley
Sat, Feb 14, 2009 at 9:04:51 AM | Scheduling Issues - rounding up
qthdad
5 Stars: 2 Votes
So, you are saying this:
If Q < 1, then Q = 1
else just keep the current value (Q = Q)
How about
Q = if(Quantity<1, Quantity +1, Quantity)
Mon, Feb 16, 2009 at 12:56:01 PM | Scheduling Issues - rounding up
bradleymatthew
Yes, exactly.  I gave that a whirl and I'm still getting higher #'s than I should.  Revit's applying that formula to each individual piece rather than the sum of all pieces, which throws my numbers off.  I think that right there is my problem - Revit cannot use the total sum of one parameter or calculated value in another calculated value - it applies the formula to each instance and THEN calculates the sum.....
If I know that a counter only come in 8' lengths, I know that I can use that one piece to make several small counters.  Traditional math would simply suggest that you add all the lengths together & divide by the known length (8') to find out how many 8' counters you would need to order.  This is different than what I'm trying to tell Revit to do - Revit is taking each small counter and trying to confirm if it fits the formula (Q = if(Quantity<1, Quantity +1, Quantity)).  If there is a piece that is under 1, it will add 1 (quantity being an 8' pieces of counter).  You can see how this will quickly throw the numbers completely off because Revit is adding (1) 8' counter for ever piece that's smaller than 1.
Bradley
Rounding in Formulas
Wed, Mar 13, 2013 at 8:49:48 AM
Dimension Rounding
Thu, Aug 23, 2007 at 2:54:31 PM
Area Tags - Rounding refuses to change
Tue, Feb 10, 2015 at 8:22:13 PM
Rounding Issue in Schedules
Mon, Jan 9, 2017 at 2:07:07 PM
Issues in Scheduling parts
Tue, May 30, 2017 at 12:54:23 PM
Page generation time: 3.8961
