Forums >> Revit Building >> Technical Support >> Stair and 2 odd shaped landings
Wed, Feb 11, 2009 at 3:13:43 PM | Stair and 2 odd shaped landings
david2006
I'm using Revit 2009 and I'm trying to create a stair with 2 intermidiate landings between 1 level. it is made up of 1 straight string, a landing, a curved stair, a landing, and then another straight stair. I can get revit to build the stairs and landings but the landings aren't quite the shape I want so when i go into sketch mode and edit them it gives me this error......"Stairs require no more than two boundries (chain of one or more boundary Lines)". Not sure what this means cause I have it drawn correctly. Frustrated so much I merely erased one of the Revit Created boundary lines and redrew it in the same way and it gave me them same error.
I've tried creating with just boundry and riser commands and that is fine until i add the 2nd landing and then I get the same error.
 what's up with the stair tool in this program.
thanks,
Wed, Feb 11, 2009 at 3:16:45 PM | Stair and 2 odd shaped landings
wheelergc
Do not put a boundry where your landings meeting the stairs, just treat the landings as one big step.
3 run stair case w/ 2 landings
Tue, Apr 3, 2012 at 2:44:18 PM
13
Revit Arch 2009; U-shaped stair with 4 runs
Thu, Jun 11, 2009 at 10:49:07 AM
overlapping multi-landing stair
Sun, Jan 24, 2010 at 7:08:37 AM
Assembled Stairs - Joining stringers from one set to the landings of another
Thu, Mar 13, 2014 at 3:13:48 AM
How do you rotate surface pattern on stair treads and landings?
Fri, Oct 23, 2015 at 4:22:40 PM
Page generation time: 1.5602
