21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> New Sub-Category for Different Sections
I've created a section tag for our glazing elevations so that we can double click the glazing tag and pull up the elevation. The only issue is theis section mark will show up in all the wall sections and elevations. I thought if I could create a new section category then I could hide that sub-category in my other views. Is this possible?
you can hide by "element" not Subcategory..
----------------------------------- BallewDesigns.com |
3 Posts No Rating |
Have tried it but it doesn't seems to work. Altough you can create a new anotation object categorie (place it under Generic Annotations) in the Section tag Family, you cannot select this categorie under subcategory when changing the element properties. Sorry.
Can we create our own category? |
Mon, Nov 23, 2009 at 7:48:26 AM
Problem with wall sweep show on wrong sections |
Wed, Mar 22, 2006 at 5:37:32 AM
Baluster category/sub category |
Tue, Nov 19, 2013 at 9:43:56 PM
Sections Referencing the drawing you want. Help Cheat! |
Fri, Feb 25, 2011 at 11:22:05 AM
Settings by category |
Wed, Aug 4, 2010 at 8:36:26 AM
