Forums >> Revit Building >> Technical Support >> Looking for someone to help with a waterslide
Tue, Feb 10, 2009 at 5:26:08 PM | Looking for someone to help with a waterslide
jdivina
HI,
I am having problems making a waterslide.  I have read some of the comments made by others for it but still find it impossible to do.
Does anybody have any suggestions on how i can do this.  Kind of like a step by step way that would be easier.
JD
Tue, Feb 10, 2009 at 6:04:59 PM | Looking for someone to help with a waterslide
robinballew
robinballew Avatar
3 Stars: 4 Votes
Did you try the ramp tool? Do you have an examle of what you need?
BallewDesigns.com
Wed, Feb 11, 2009 at 9:55:48 AM | Looking for someone to help with a waterslide
jdivina
HI
so i haven't tried to use the ramp tool because i don't know how to use it to make a slide.
i have an example of the waterslide that runs into a runout lane.  and it would start at 6868m above ground.
any ideas would be greatly appreciated.
thanks
JD
Wed, Feb 11, 2009 at 10:08:05 AM | Looking for someone to help with a waterslide
jdivina
k my example doesn't seem to be loading
JD
Wed, Feb 11, 2009 at 10:19:50 AM | Looking for someone to help with a waterslide
jdivina
k ignore the kobe wall paper
but the slide is on the right side
JD
Wed, Feb 11, 2009 at 10:22:54 AM | Looking for someone to help with a waterslide
jdivina
JD
Wed, Feb 11, 2009 at 10:24:04 AM | Looking for someone to help with a waterslide
jdivina
here it is
ignore the kobe wallpaper haha
its the one on the right
had to put it on the document cuz the size was to big
JD
Wed, Feb 11, 2009 at 12:49:41 PM | Looking for someone to help with a waterslide
KingRevit
4 Stars: 12 Votes
ok i had the very same before, if i'm write it is a tube twisting that you are looking for,
i will have to look in my archive , but i think the best solution is a giant hand rail railing on an invisible spiral stairs.
of course you could make it in autocad, rhino, inventor, 3ds max etc.
its late so i'm off home for the night but i will try to find the one i made before and post it for you.
Wed, Feb 11, 2009 at 2:11:39 PM | Looking for someone to help with a waterslide
jdivina
ok
thanks
JD
Waterslide???
Thu, Apr 6, 2006 at 4:44:13 PM
Page generation time: 2.0318
