Forums >> Revit Structure >> Technical Support >> Wood Stud wall
Tue, Feb 10, 2009 at 3:09:22 PM | Wood Stud wall
jolitch
I was wondering if there was a program that you can design a wood wall and import it into revit or a family that has been created to develop a stud wall inside of revit.  I need to be able to take a live section and see the studs in the walls at the appropriate positions ex. 16" o.c., headers
Thanks
Tue, Feb 10, 2009 at 6:01:52 PM | Wood Stud wall
robinballew
robinballew Avatar
3 Stars: 4 Votes
Beam system. Define the plane and use the 2x4 or 2x6 or what ever. It will not add the headers but those need to be designed based on the load.
BallewDesigns.com
Wed, Feb 11, 2009 at 2:28:33 PM | Wood Stud wall
jolitch
I was not able to set the plane at vertical how did you do it again
Wed, Feb 11, 2009 at 3:00:12 PM | Wood Stud wall
mrmoo
mrmoo Avatar
2 Stars: 1 Votes
Set a Reference Plane parallel to your wall at the desired loaction and set that as the work plane for your beam system.
Wed, Feb 11, 2009 at 3:09:17 PM | Wood Stud wall
robinballew
robinballew Avatar
3 Stars: 4 Votes
I attached a sample file. Please look at it and see if it helps. I used a Beam System, Individual Beams (2x6's, 2x10's, and I had some wall sweeps for the top and bottom plates.
BallewDesigns.com
Thu, Feb 12, 2009 at 9:05:51 AM | Wood Stud wall
jolitch
I got it thanks alot for your help, I appreciate it
Wood Stud Wall Cut Patterns
Mon, Feb 29, 2016 at 7:36:50 AM
Wood frame projects
Mon, Nov 14, 2016 at 3:41:23 PM
How to create a 2x6 wood stud
Wed, Oct 16, 2013 at 2:24:57 PM
Wood studs
Mon, Mar 31, 2008 at 2:24:59 PM
wood stud wall creator 3rd-party software?
Sun, Jun 28, 2009 at 4:12:19 PM
Page generation time: 1.4326
