26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Rendering Stoppage
Last week I was able to setup and scene and leave it render overnight (about 13 hours of rendering time); I made a few changes to the model and now when I go to render a scene for overnight I leave and come back the rendering has stopped, the progress bar is at 100%, but the time is only at 8-9 hours (it varies) and the rendering is only about halfway through the first pass. I'm not sure if this is a scene setup thing (it would be nice if you could save scene setups), a memory thing or some sort of a server disconnection.Any advice would be greatly appreciated!Thanks!
cad.web.print website: http://www.thinkdesign-studios.com blog: http://www.bimtionary.blogspot.com/ |
I have had similar issues. Do you have the Screen Saver on.. I started to turn it off and just shut off the screen and it seems to help. Not sure why..
----------------------------------- BallewDesigns.com |
Hi Bm3875, "I made a few changes to the model...", what kind of changes did you make?. I noticed that sometimes, this happend to me when I imported components made with high polygons (specially from 3ds Max). But, how many RAM or/and virtual memory do you have?.Also, as robinballew did, I turn off the screen saver and really helped.
1 Posts No Rating |
I'm going to bump this thread because I'm having a similar problem. My system specs: Windows XP Professional 32 bit 3.0 GHz Dual core 4 gigs of RAM (only about 3.25 gigs recognized) EVGA 8800 graphics card I was trying to render an image at 150 dpi with a size of about 14in by 8in and it stopped sometime overnight (at least 13 hours into the rendering). There were no error messages. As suggested in other threads, I updated Revit 2009 with the service pack. I did not have any other programs running at the time except for the task manager, and it displayed that I was only using about 1.4 gigs of memory. If anyone has some suggestions it would be appreciated!
Realistic Rendering [ 1 2 ] |
Thu, Aug 4, 2011 at 2:30:37 PM
25
2 Days Rendering...38% Complete 2009 Slow Rendering [ 1 2 ] |
Wed, May 13, 2009 at 7:36:39 AM
22
09' Rendering Issue |
Wed, Jun 3, 2009 at 4:22:51 PM
11
Going from Rendering in RA 2008 to Rendering in RA 2009 |
Mon, May 11, 2009 at 4:32:50 PM
help with rendering! |
Wed, Aug 10, 2016 at 10:47:17 PM
