Forums >> Revit Building >> Technical Support >> Room/area tags on floor plan with demo'd wall
Tue, Feb 10, 2009 at 9:03:12 AM | Room/area tags on floor plan with demo'd wall
aaronkennedy
I am having a slight problem with a demo'd wall still acting as room bounding.  I split a wall and demo'd part of it.  The part I demo'd is still acting as room bounding?  Any one experienced this before and know how I can work around it?
Thank you,
AAron
Tue, Feb 10, 2009 at 9:08:28 AM | Room/area tags on floor plan with demo'd wall
4 Stars: 205 Votes
Did you uncheck that parameter (room bounding) in the properties of that wall???
Tue, Feb 10, 2009 at 9:53:41 AM | Room/area tags on floor plan with demo'd wall
aaronkennedy
Thanks Typhoon,
It was an exterior wall that had ben turned into an interior wall when an addition was added.  I still had it as exterior.  I changed it to an interior wall and the problem solved itself.
 Thanks again
AAron
Room Tags not showing up in Floor plan.
Tue, Nov 9, 2010 at 1:06:50 PM
Demo Plan Room Tags
Thu, May 12, 2022 at 9:21:44 PM
changing the scale of my room and area tags with the scale of my area plan.
Fri, Oct 22, 2010 at 10:38:38 AM
Room Tags and Crop Regions
Wed, Sep 28, 2005 at 10:41:25 AM
room tags and demo
Tue, Apr 6, 2010 at 1:13:11 PM
Page generation time: 2.2474
