Forums >> Workflow & Implementation >> Hardware >> Vista 32, Revit Arch 09, file opening issue
Mon, Feb 9, 2009 at 10:41:38 PM | Vista 32, Revit Arch 09, file opening issue
Sven
3.5 Stars: 3 Votes
Here's one that we have been trying to solve today with no luck so far...
We have a revit project file here in our office that was mistakenly set up by the user as a template file, which the user couldn't open - each time it gave hime the error "file cannot be opened as it is open by another user - try again later" (or words to that effect). So i fixed the template problem by using the template file to start a new project... (so now the .rte file is a .rvt file) but we still can't open the file on that particular PC.
We have tried opening the file on a newer PC and have had spurratic luck. i currently have them open, and I have noticed that this then allows me to open them read-only on the original PC - but I can't re-save it under another name on that PC (although i can re-save on the newer PC).
I have tried turning the fire-wall off, re-booting etc. however still no luck. I have even updated Revit and Windows Vista to the latest versions/updates on the original PC...
One thing we do have that could be part of the issue on the original PC is an error message on boot-up that 'host processes' have stopped working.. i start to get a bit lost here though...
Can anyone offer any advice on what to try next....thanks in advance.
Thu, Feb 12, 2009 at 12:02:10 PM | Vista 32, Revit Arch 09, file opening issue
need4mospd
This may work...
1. Open the project through the template method you described
2. Copy the elements using ctrl-c
3. Paste the elements using ctrl-v into a new project
4. Extensive staff training
Thu, Feb 12, 2009 at 3:24:23 PM | Vista 32, Revit Arch 09, file opening issue
Sven
3.5 Stars: 3 Votes
thanks for your help need4mospd! i agree with your point 4 wholeheartedly - that same staff member used a blue filled region to make it look like his door was glazed in elevation! i coudln't decide if i should laugh or berate this guy...so training is a no brainer...
I'll try doing this today, although we may be having some hardware issues as we had a problem saving an excel file yesterday.
weirdly enough - when that particular PC can't access a file, it's like it's corrupting the file or something, because no-one else can access it after that... until a day or so later... I'm starting to wonder if it's not revit, but more our network configuration. Our support company are leaning the same way.
It really is perplexing so i'd love to hear other's thoughts.
ARCH OPENING IN IN PLACE WALL COMPONENT
Thu, Jun 14, 2012 at 2:04:06 PM
Revit files that cannot be deleted in vista
Tue, Mar 24, 2009 at 3:33:39 PM
HP DESIGN JET 1050C FOR VISTA 64 BIT
Fri, Apr 18, 2008 at 6:39:35 PM
updating a revit arch model error (REVIT 12)
Fri, Mar 1, 2013 at 4:06:42 PM
User Material file Location in Vista
Wed, Sep 23, 2009 at 11:23:50 PM
Page generation time: 2.7331
