Forums >> Revit Building >> Technical Support >> "Furniture tag"
Tue, Jun 14, 2005 at 7:23:57 AM | "Furniture tag"
Owjan
Hi!
I have a closet-familj and and want to have a letter in it foe each type of closet.
for exampel a G for Garderobb and a L för linneskåp. It has a label "Show" and a label for angel.
When i put the closet in side my draft I want to be able to
a: Change the letter
b: Chnage the angeleav letter
c: The letter shuld always be att the center of the closet.
But it would be better if some how the letter was always horizontal regards what angle the closet have.
Any proposals??
Wed, Jun 15, 2005 at 7:20:05 PM | RE: "Furniture tag"
DanielHurtubise
You will need to create a general annotation family and insert it your furniture family. Use a shared parameters for you letters. Placement will be inside the furniture family and for reading, check under settings for keep readable
Wed, Jun 15, 2005 at 9:12:16 PM | RE: "Furniture tag"
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You could also set it up via shared parameters and tags. Add shared parameters to your closet family for the information you want to report then create a tag for the category you are using for the closet (casework?) that reports these shared parameters then tag in the project. This is a fairly advanced process to setup, but is the best way to achieve what your after. HTH.
Cant Tag Furniture. keeps asking to load furniture tag
Sun, Dec 9, 2012 at 6:59:11 PM
"Tag by category" of Architectural Column in Plan
Thu, Apr 16, 2009 at 2:45:20 PM
tagging by "family name" and "family type"
Mon, Jun 1, 2009 at 8:54:54 PM
Help. I forgot how I "turned off" the room tags.
Tue, Oct 8, 2013 at 7:18:18 AM
11
Text as a yes/no parameter in a Tag
Wed, Sep 29, 2010 at 11:02:06 AM
Page generation time: 2.0040
