Forums >> Revit Building >> Technical Support >> How to do breaklines?
Mon, Feb 9, 2009 at 9:51:36 AM | How to do breaklines?
Ryan44
Hi I dont know how to get breaklines to show up. I need to split a section to fit it on a sheet. Ive pressed the breakline button on the crop view, but nothing is coming up. Then when i draw a line its invisible because its outside the crop region. How do I get breaklines to show up.
 Thanks
Mon, Feb 9, 2009 at 9:56:04 AM | How to do breaklines?
The "breakline" is a detail component - you will find it under drafting tab
Mon, Feb 9, 2009 at 9:58:56 AM | How to do breaklines?
4 Stars: 205 Votes
"I need to split a section to fit it on a sheet."  -  Aren't you talking "Matchline"????
Mon, Feb 9, 2009 at 10:11:05 AM | How to do breaklines?
Ryan44
I dont know if I'm talking matchline. I drew a matchline and nothing was cut or anything, so I just moved the crop region and thought I could draw a breakline. Obviously I'm doing it the wrong way. How else do I do it then? Anything to make it easy on me since I'm new at this.
Mon, Feb 9, 2009 at 11:19:01 AM | How to do breaklines?
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I've not done it but what about making a copy of the view, cropping them together
Mon, Feb 9, 2009 at 12:02:02 PM | How to do breaklines?
tim123
4 Stars: 19 Votes
Matchlines work with dependant views.  Look at the help under 'Duplicate dependant views'.
Mon, Feb 9, 2009 at 8:09:15 PM | How to do breaklines?
jarosa
jarosa Avatar
4 Stars: 5 Votes
Ryan,
When you highlight the crop region on a section view (you need to do this in view not on the sheet) you will see a small (really small) break symbol right on the crop line. click it. use the arrows to move the sections closer together. you can split it again if you want to. Then use the detail component Break Line as usual. In case you haven't discovered yet the space bar rotates and aligns objects. use the space bar to flip the break lines as needed. I think this is what you're after. Good luck
John
breaklines
Thu, Feb 28, 2008 at 10:56:30 AM
Ramp breaklines
Tue, Apr 16, 2019 at 5:37:49 AM
Breaklines print out with a big masking block attached... Help!
Thu, Apr 28, 2005 at 10:22:15 PM
Exporting Sections to AutoCAD
Thu, Jun 16, 2005 at 11:45:29 AM
Topo surfaces Wont Do Concave shapes
Sat, Dec 11, 2010 at 9:16:04 AM
Page generation time: 0.0218
