Forums >> Revit Building >> Technical Support >> Tagging site plan. Filled Regions?
Fri, Feb 6, 2009 at 11:33:47 AM | Tagging site plan. Filled Regions?
Ryan44
My office has just switched over to Revit and I'm doing a site plan. I'm pretty much brand new at it, I've had a bit of training...Anyways I've ended up doing the existing site plan in line drawings just because the survey I was using was flat and I didnt want to go edit everything in that drawing. Now I'm putting down filled regions to show things like asphalt, grass, concrete, etc. I would like to use a tag to show what the materials are but I cant get the filled region to be tagable, obviously it isnt tagable, or I am not doing something wrong. Is there any way I can tag the filled region? Or is there another alternative to tagging the areas I want to?
Thanks
Fri, Feb 6, 2009 at 12:10:25 PM | Tagging site plan. Filled Regions?
Do you mean tag or keynote?
Obviously - filled regions are not model elements so how could they tag?
If you are using keynotes, select user from your keynote and then point to a model element and pick your keynote.  Change the keynote to free end and then move it to your filled region.
YOU MUST REMEMBER - THIS IS A SMART KEYNOTE AND IT THINKS YOU ARE KEYNOTING A MODEL ELEMENT.  IF THAT MODEL ELEMENT (which may be clear across the sheet) IS TURNED OFF OR DELETED, YOUR KEYNOTE WILL GO AWAY.  A fix for this is to place a model family that just has an invisible line in it and place that in your filled region.
Fri, Feb 6, 2009 at 12:14:59 PM | Tagging site plan. Filled Regions?
Ryan44
Well I actually did mean keynote now that I think of it more.
And I didnt know that filled regions are not model elements, I am brand new to this program.
 Thanks for the answer, Ill try it out.
Filled Regions and families
Sun, Mar 8, 2009 at 7:10:29 PM
Filled Regions - How to make them show in all views
Thu, Nov 21, 2013 at 3:53:29 PM
filled in regions
Mon, May 2, 2005 at 1:08:09 AM
Masking Regions and Filled Regions BEHIND 3D Objects
Wed, Aug 1, 2012 at 8:10:27 AM
Filled Region Not Moving
Wed, Jun 10, 2009 at 9:18:11 AM
Page generation time: 0.4739
