Forums >> Revit Building >> Technical Support >> Error when inserting stair
Fri, Feb 6, 2009 at 7:41:09 AM | Error when inserting stair
OleBanshee
Every time i click to add a stair to my model i keep getting an error that says "A serious error has occured.....".  This seems to be the only thing that generates the error.  All other functions work like walls, doors, ramps, etc work fine it is only the stairs that will not work.  Does anyone have any suggestions on how to correct this problem.
Fri, Feb 6, 2009 at 8:06:30 AM | Error when inserting stair
coreed
coreed Avatar
4 Stars: 16 Votes
does this happen in all files? have you ever been able to use the stair tool?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Feb 6, 2009 at 11:56:07 AM | Error when inserting stair
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Have you tried to install Revit service pack 3?......
Simple Stair Nosing error
Thu, Mar 5, 2015 at 9:15:24 PM
stair railings-inserting glass
Mon, Dec 9, 2013 at 11:37:40 AM
Stair Command
Wed, Aug 31, 2016 at 3:32:54 PM
Stair Material Takeoffs - Volume Calculation Error when Painting
Tue, Dec 10, 2013 at 7:45:46 AM
Monolithic stair - large construction height error
Thu, Oct 13, 2011 at 12:10:33 PM
Page generation time: 1.6785
