Forums >> Revit Building >> Technical Support >> .dwg import & drawing order
Fri, Feb 6, 2009 at 6:06:30 AM | .dwg import & drawing order
kryan
Revit structure 2009. Having problems with architects backround.See attached images.
images 1-cad imported using>link.current view only.Colors>black & white.Then halftone>foreground(drawing order)
image 2-cad import using >link.current view only.Colors>Black & white. Then halftone>backround(drawing order)
How can i get the architects backround to print so i can see it as in the first image, but it doesnt block out my slab lines (weight 5) and structure columns & walls?
Please help.I have also tried changing cad import to transparent, same result.
Can't import dwg or dxf to RS2008
Wed, May 30, 2007 at 10:36:07 PM
Dwg Site Import
Tue, Feb 21, 2006 at 5:12:40 PM
Revit Arch2012 Import simple A/Cad legend
Fri, Nov 16, 2012 at 4:13:16 AM
Import DWG problem with size
Mon, Dec 6, 2010 at 7:33:32 PM
export to viz
Mon, Sep 26, 2005 at 3:04:27 PM
Page generation time: 3.2449
