Forums >> Revit Building >> Technical Support >> Steel pan Decking
Wed, Feb 4, 2009 at 12:25:51 PM | Steel pan Decking
designkern
Wanting to have steel pan decking exposed. I would like to model that as a floor system, any suggestions?
Wed, Feb 4, 2009 at 1:02:57 PM | Steel pan Decking
4 Stars: 205 Votes
Images of what do you want???
Wed, Feb 4, 2009 at 1:05:03 PM | Steel pan Decking
Really ???  You may really bog down your model.  If you have to see it in a 3d then it would be easier to use a bitmap texture.
You could look at creating a parametric slab family but odd shapes would be a problem.
You could create an inplace family with individual rib sections that are arrayed in the family.
Wed, Feb 4, 2009 at 1:11:27 PM | Steel pan Decking
designkern
Yeah well these guys just cant get enough of corrugation.  I am just surrprised that its not a existing parametric slab in Revit since the structural modeling SLAB tab looks like a steel pan section, but what can you expect when the rendinging icon is a curse tea pot.  Hold on i think i am blowing off some steam!
steel pan visibility in 3D view ?
Sun, Jun 4, 2017 at 1:49:03 PM
Modifying stairs to use custom steel stair pan
Fri, May 16, 2008 at 1:01:00 AM
making steel decking
Thu, Jul 2, 2009 at 6:45:07 AM
Composite decking
Sat, Mar 27, 2010 at 8:43:41 AM
Merbau Decking
Sat, Feb 25, 2012 at 10:35:44 AM
Page generation time: 0.0768
