Forums >> Revit Building >> Technical Support >> Window openings, actual window and structural opening size
Wed, Feb 4, 2009 at 9:25:50 AM | Window openings, actual window and structural opening size
stuhadfld
Hi there,
Is there a simple way of setting windows so that they are recognisable as say, a 1200x1200mm window unit, sitting in a 1210x1210 structural opening? I can size the windows correctly, but then all my setting out drawings are wrong and vica versa, as it won't let me add real world tolerances. I had hoped that the "rough width" etc parameters were referring to structural sizes, but when "rough width" is changed, "width" is changed.
 Any advice appreciated.
 Stuart
Thu, Feb 5, 2009 at 11:16:19 AM | Window openings, actual window and structural opening size
rquist
seems that some windows do recognize diff. between r.o. and unit size & some don't. I'm sure it's in the way they were created.  I just found a different window that responded in the way I needed them to.
Assembly Schedule - structural opening
Sat, May 12, 2012 at 2:57:25 AM
place window in an opening
Wed, May 26, 2010 at 10:23:54 AM
Actual Window Head height
Thu, Jun 7, 2007 at 5:44:29 PM
Angled window opening in plan view
Thu, Aug 15, 2013 at 2:18:12 PM
11
view window size
Thu, Jan 8, 2015 at 10:38:12 AM
Page generation time: 0.4788
