Forums >> Revit Structure >> Technical Support >> Amending Construction Start/End Extension
Wed, Feb 4, 2009 at 3:44:57 AM | Amending Construction Start/End Extension
Allan1983a
Within the Element properties of any beam it has the Construction Sub Category with Start and End Extension.  This is as standard set to -12.5 on my model.  Is there a way as standard to change this to say -100 so any new beams (and the existing ones is have drawn) show with this larger extension (this is needed to ease reading for engineers and site erectors)
 Cheers
 Allan
Wed, Feb 11, 2009 at 4:57:07 AM | Amending Construction Start/End Extension
FJ22
I think the only way is to edit the beam family...
But if so, you're gonna adjust every different type of beam seperately. So it's not really easy to do. But if you want it all the time it might be usefull.
Greetings,
Frank
Objects being cut
Thu, Mar 8, 2018 at 3:15:13 PM
Beam start/end extension
Fri, Feb 12, 2010 at 10:59:48 AM
Spiral Stair I Need to start at 90 degrees and end at 90 degrees [ 1 2 ]
Wed, Feb 19, 2014 at 12:40:38 PM
15
Extended 2 1/2" joist end with a 5"+ seat bearing?
Thu, Sep 29, 2011 at 3:07:20 PM
Any way to determine which end is Beam/Joist Start or End
Mon, Feb 1, 2010 at 7:10:23 AM
Page generation time: 1.5936
