Forums >> General Discussion >> Revit Project Management >> Sloped Rood
Tue, Feb 3, 2009 at 6:59:11 PM | Sloped Rood
jgmas
Is there a way to model a sloped roof with a gable end ?
 See attached image
Tue, Feb 3, 2009 at 7:09:30 PM | Sloped Rood
jarosa
jarosa Avatar
4 Stars: 5 Votes
jgmas,
Looks like you want a shed roof. If that's the case, when sketching the roof set "defines slope" to the front part of the roof only. Then attach walls to roof.
HTH,
John
Tue, Feb 3, 2009 at 11:59:34 PM | Sloped Rood
Sven
3.5 Stars: 3 Votes
so if I'm understanding your sketch, you want to have a variable pitch to the side faces of your roof - is it a gable at the rear as well? If this is true, then you may need to mass your roof - using "solid blend" sketch your front gable and then your rear gable, and then select 'roof by face' to convert...
Rood Perimeter
Thu, Feb 1, 2018 at 3:55:18 AM
Sloped terrain and sloped foundation wall
Thu, Sep 3, 2009 at 1:57:36 PM
order of design
Wed, Jun 24, 2009 at 6:36:44 AM
sloped walls
Wed, Oct 13, 2010 at 1:28:16 PM
Sloped Railing
Fri, Nov 21, 2008 at 11:31:01 AM
Page generation time: 0.0439
