Forums >> Revit Building >> Technical Support >> Problem aligning hip rafter on hip roof exactly where i want it. RAC 2009
Tue, Feb 3, 2009 at 6:00:39 PM | Problem aligning hip rafter on hip roof exactly where i want it. RAC 2009
twhisker
2.5 Stars: 5 Votes
I am trying to create a basic hip roof.  We want the hip rafter to cross over the intersection of our structural grid system so that columns and trusses can pick up the load.  When I setup the eaves to align, then I miss the intersection of the structural grids.  We did a pathegreon calculation to figure out the slope.  The problem is that A) it is slightly off and I know Revit can be exacting in its math and B) if anything changes, we have to recalculate the slope.  Is there a way to dictate exactly where you want your hip rafter to be?  Please see attached file.  Thanks.  RAC 2009
Revit Architecture 2010
Tue, Feb 10, 2009 at 6:37:31 PM | Problem aligning hip rafter on hip roof exactly where i want it. RAC 2009
robinballew
robinballew Avatar
3 Stars: 4 Votes
To get the structural beam on the hip just use the 3D Snapping selection in the Option bar. If the pitch keeps changing you will have to keep updatig the beam. You can check http://www.tools4revit.com/truss-plus/overview/ I think they have developed some tools that solve the update issues.
BallewDesigns.com
Drawing a hip rafter in massing
Tue, Aug 12, 2014 at 4:33:03 PM
Hip Roof Issue
Mon, Mar 24, 2008 at 1:30:08 PM
Partial Hip Roof
Tue, Jun 26, 2007 at 3:22:10 PM
Issue Aligning two roofs that exist on different levels.
Tue, Mar 20, 2007 at 6:06:16 AM
Roof hip with different height fascia
Mon, Sep 9, 2013 at 2:25:27 PM
Page generation time: 0.6473
