Forums >> Revit Building >> Technical Support >> Stair visible through floor
Tue, Feb 3, 2009 at 3:02:35 PM | Stair visible through floor
Voss
We have created a L-shaped stair from the basement to our first floor. The stair shows up in the first floor plan however, once it passes beyond the the boundaries of the opening we cut in the slab it is still visible as if the slab does not even exist. No other elements of the basement level are visible.
Does anyone have a suggestion what to check?
Tue, Feb 3, 2009 at 5:45:55 PM | Stair visible through floor
jarosa
jarosa Avatar
4 Stars: 5 Votes
wireframe?
Wed, Feb 4, 2009 at 7:30:53 AM | Stair visible through floor
Voss
I've checked wireframe, I've played with view properties, I even saw someone suggest that the floor might be set to transparent...nothing I've found using search has helped me so far.
Wed, Feb 4, 2009 at 8:10:46 PM | Stair visible through floor
jarosa
jarosa Avatar
4 Stars: 5 Votes
voss,
so it's not in wireframe.....any way the floor is hidden? select the area around the opening and see if floors show up in the filter dialog. post a screen shot.
John
Thu, Feb 5, 2009 at 7:25:44 AM | Stair visible through floor
Voss
aaaaahhhhh!!!!!
 So apparently, my CAD guy decided to hide the floor so the concrete hatch would not show rather than turn off the fill pattern.
 Thanks for having me double check that. I almost feel better now.
Thu, Feb 5, 2009 at 5:21:21 PM | Stair visible through floor
jarosa
jarosa Avatar
4 Stars: 5 Votes
you're welcome.
john
Stair Arrow visible only in one view?
Thu, Oct 11, 2012 at 2:19:25 PM
Stairs - viewing from floor above.
Wed, Jan 16, 2008 at 11:26:18 AM
Stairs to second floor showing full stair
Thu, Jun 4, 2015 at 9:44:02 AM
12
Hide door swings which are visible from floor below
Wed, May 6, 2015 at 12:16:03 PM
Floor Slab not visible in Plan!
Tue, Nov 9, 2010 at 1:58:17 PM
Page generation time: 3.7054
