29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> Room Tag with Occupant Load
11 Posts No Rating |
Has anyone seen (or have to share) a room tag rfa that calculates and displays occupants per room (like for a code egress plan)? We have all seen room tags that show area of a room. Take it a step further where you enter the area allowance per occupant and revit calculates and shows the occupants per room. e.g. Classroom 525 SF / 20SF/occ = 27 occ Graphically i have typically seen this as 3 numbers in a rectangle - the area on top (525SF), and the allowance (20) and occupant load (27) on the bottom. If its out there, this would be a huge time saver. Please dont tell me to create the family unless you are willing to explain how. Thanks, Pw
This has been discussed many times. Use "occupancy" as a search in the forum area and you will find several posts on what you can and can't do.
Thanks, yes I found those posts. The TomDorner and Bauhaus1919 posts from 2006 were very helpful. i was able to get this working via the new shared parameters route...and creating a dummy column in a schedule that i manually copies over the data to the "tagged" parameter. This was a huge time saver and very worth while. Pw
occupant load factor |
Fri, Oct 14, 2011 at 10:31:08 AM
Occupant Load Factor Tag |
Thu, Feb 10, 2011 at 8:34:42 AM
Calculating occupant loads using room schedule |
Wed, Mar 7, 2007 at 4:45:12 AM
Room Tags That Calculate [ 1 2 ] |
Mon, Feb 17, 2014 at 3:28:45 PM
22
room tag with occupancy info (2019) |
Thu, Jan 24, 2019 at 1:34:42 PM
