Forums >> Revit Building >> Technical Support >> Missing Level
Tue, Feb 3, 2009 at 10:11:35 AM | Missing Level
rboaz
I have a level that does not appear in any views or the project browser. It only appears in the Plane Dialog or in element properties as a level to constrain to. I have tried everything I can to find the layer to delete it (It does not control anything). Help is appreciated
Tue, Feb 3, 2009 at 10:34:11 AM | Missing Level
tim123
4 Stars: 19 Votes
If it constrains elements then it does control something and the elements will be deleted along with the level.  Have you revealed hidden elements to try and find it?
Tue, Feb 3, 2009 at 10:41:27 AM | Missing Level
rboaz
I have unhidden everything in all elevations and the level does not appear. I do not mind losing any elements if I can find and delete this layer.
Tue, Feb 3, 2009 at 11:06:03 AM | Missing Level
A couple of thoughts about this.  If anything was created using this leval as a plane, then even if the level is deleted, the plane will probably remain until the element that uses it is deleted.
If the level exists as a level, you should see it in the pull-down when you  click on floor plan to create anothr plan.  Otherwise, it may exist as a plane with the name Level xxx.
Tue, Feb 3, 2009 at 3:20:24 PM | Missing Level
rboaz
This did not work. I also tried clicking on the crop region for the plan for that level and asked for referring views and it came back that it "could not find referring views"
Tue, Feb 3, 2009 at 3:50:42 PM | Missing Level
rboaz
Problem solved. The level was on a workset whose visibility was turned off. Thanks for your help
LEVEL Annotation Missing
Mon, Dec 11, 2006 at 3:41:47 PM
Missing Level symobl on Sections
Tue, Oct 10, 2006 at 1:30:56 PM
Level Lines missing
Fri, Sep 26, 2014 at 8:09:18 AM
Ref Level Missing in Family Editor 2013
Thu, Aug 22, 2013 at 5:05:39 PM
Wall schedule - level field missing
Fri, Mar 27, 2009 at 8:13:10 AM
Page generation time: 0.6198
