22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Beam & Column tags
7 Posts No Rating |
Beam & Column tags somhow do not lable the "Mark" for sequential numbering as in doors and windows.
I have tried to edit Beams & column tags without any luck.
I would like my beams and colums tags to number these elements e.g BM1 or C1 etc.
I can add it manually which is time consuming. Is there a way to automate this process like in doors and windows?
AFAIK I don't think you can do that, though normally colums will be tagged according to type, i.e column C1 is 300x300 and C2 is 400x400 and this can be done by changing the tag to "Type Mark" otherwise change to "Mark" and edit each one...
Yep editing each one is the only method i wish they were auto numbering also... Its on the wishlist.
Most importantly for carparking tags...
How to extend top flange of beam (over top of column)? |
Fri, Jun 15, 2012 at 10:35:08 AM
How to show beam column connection in plan properly |
Fri, Nov 7, 2014 at 12:53:30 PM
Tee beam as column? |
Tue, Nov 6, 2012 at 2:41:46 PM
beams not snapping to beam/column |
Fri, Feb 19, 2010 at 4:30:22 PM
Column Family/Beam Family |
Fri, Aug 27, 2010 at 1:25:52 PM
