Forums >> Revit Building >> Technical Support >> perspective angle
Mon, Feb 2, 2009 at 8:00:28 PM | perspective angle
mino
HI,
I am rendering interior view of a room with outdoor view. When I'd used camera to shoot a view from corner of room, I got really small view of outdoor area due to perspective angle. What I want to know that can you changed angles or diminished point of perspective? I want things far away from camera is bigger.
Please can somebody help me with this?
 Thanks
 Mino
Tue, Feb 3, 2009 at 8:37:22 AM | perspective angle
tim123
4 Stars: 19 Votes
Adjust your camera angle.  You can hide the wall behind the camera to move it back and view a larger part of the room.
Wed, Mar 28, 2012 at 4:13:37 PM | perspective angle
laurablosser
How do you adjust the camera angle? I'm using Revit 2012 and can't figure it out.
Thanks.
Thu, Mar 29, 2012 at 7:43:10 AM | perspective angle
Two things here.
  1. Camera "lens".  Revit uses a near normal "lens" and this stops distortion.  You can in essance widen that lens by grabbing the grips on the sides of your viw and stretching them out.  Be careful - it will distort.
  2. Normal camera view do not work well in interiors.  Therefore, I do like tim123 suggests and I place the camera outside the room.  Then I hide the walls that block my views.  This is more like most interior renderings.
Perspective Problem
Fri, Jun 26, 2009 at 12:13:43 PM
Sectional Perspective NOT cutting in the N,S,E and W direction
Mon, Oct 3, 2011 at 2:29:47 PM
Building Material Patterns disapear at tight perspective angle
Sun, Aug 10, 2014 at 3:25:39 PM
Wishlist - Default perspective 3d view
Fri, May 2, 2014 at 9:31:09 AM
Linework Blue Grip in Perspective?
Wed, May 29, 2013 at 8:10:21 AM
Page generation time: 0.6625
