Forums >> Revit Systems >> Technical Support >> Importing a 3D mesh model into Revit and creating the mesh to solids
Mon, Feb 2, 2009 at 5:33:27 PM | Importing a 3D mesh model into Revit and creating the mesh to solids
iREV
3.5 Stars: 3 Votes
I am trying to import a 3D mesh model and trying to change it into a solid model so I can render materials in the file.  Does anyone know how to do this?
Tue, Feb 3, 2009 at 3:32:15 AM | Importing a 3D mesh model into Revit and creating the mesh to solids
4 Stars: 205 Votes
Ok, in your project go to "Massing" and create a new mass, give it the name and go to File>import>Cad formats, finish the sketch, you CAN'T create Floors by face because it's a 3d mesh not ACIS solid but you can create curtain system by face...
Tue, Feb 3, 2009 at 9:25:26 AM | Importing a 3D mesh model into Revit and creating the mesh to solids
If this is an autocad file, you can import it into a family.  Each layer in cad can be assigned a different material.
Tue, Feb 3, 2009 at 11:34:45 AM | Importing a 3D mesh model into Revit and creating the mesh to solids
iREV
3.5 Stars: 3 Votes
Typhoon, your method does not work.  I am unable to finish the sketch.  WWhub, this file is a .dwg imported from Rhino.  While I am able to change the material of the layers once imported into the project the materials are unable to render.  I tried a 3rd party autocad plug-in which changes meshes to solids.  This did not work either. Any other suggestions?
Tue, Feb 3, 2009 at 11:56:29 AM | Importing a 3D mesh model into Revit and creating the mesh to solids
irev,
If you imported it in a family, then the layers are automatically assign a material - you just have to redefine it.
Tue, Feb 3, 2009 at 12:06:44 PM | Importing a 3D mesh model into Revit and creating the mesh to solids
iREV
3.5 Stars: 3 Votes
WWhub, I did assign the materials when imported into the family.  However, when I imported it into a new project and rendered with sunlighting and sky, the sky shows up and the entire family is just a black object.  Any suggestions?
Tue, Feb 3, 2009 at 12:28:19 PM | Importing a 3D mesh model into Revit and creating the mesh to solids
iREV
3.5 Stars: 3 Votes
WWhub, I figured it out.  This was a no brainer after I created the family and imported the family into a project.  What I needed to do is change the view properties to Architectrual (I am using MEP).  This seems like it will work great! Thanks
Fri, Jul 16, 2010 at 10:05:13 AM | Importing a 3D mesh model into Revit and creating the mesh to solids
teaberries
Can anyone please tell me how to change the layers into materials once  the mesh is imported in a family? I was able to load the 3d mesh in a family but I have no idea on how to add materials to it.
 will it show a solid stair once I import it to project? or is it only solid if I render it?
thanks you guys Smile
Fri, Jul 16, 2010 at 10:45:40 AM | Importing a 3D mesh model into Revit and creating the mesh to solids
4 Stars: 205 Votes
"Can anyone please tell me how to change the layers into materials once  the mesh is imported in a family? I was able to load the 3d mesh in a family but I have no idea on how to add materials to it." - About thi: you have lots of threads here in the Forum, if you search for "Sketchup" you will see...
"will it show a solid stair once I import it to project? or is it only solid if I render it?" - Did you try it?
Will not work, it's a "Mesh" not a ACIS solid, you must convert that to a SOLID... try it too
Sun, Jul 18, 2010 at 5:52:03 AM | Importing a 3D mesh model into Revit and creating the mesh to solids
4 Stars: 205 Votes
Another thing, to convert that Mesh to a Solid use this LISP routine in CAD: "M2S.LSP" (just download from here: http://www.accustudio.com/index.php?option=com_content&view=article&id=48&Itemid=58)
Thu, Dec 15, 2016 at 9:20:20 AM | Importing a 3D mesh model into Revit and creating the mesh to solids
#11
rrvivancos
Hello, you must to select all objects of CAD file and change them into colour properties, by layer, usually is assigned one colour when you convert a 3d object into CAD. Then wehn you import this file to Revit, you can change the materials of layers, because them are with colour by layer, also if you don't do this you will be unable to change materials of imported files. is very easy...try it.
Wire Mesh Handrail
Mon, Dec 20, 2010 at 3:58:42 PM
Creating Free form mesh
Sat, Jul 29, 2006 at 11:01:57 AM
3d mesh
Thu, Feb 16, 2006 at 9:01:11 AM
Editting a mesh in Revit, is it possible?
Thu, May 23, 2013 at 7:42:42 PM
Wire mesh curtain wall door for wire mesh wall
Mon, Sep 17, 2012 at 2:57:36 PM
Page generation time: 1.7268
