Forums >> Revit Building >> Technical Support >> How the get back the model on the 3D tab.
Mon, Feb 2, 2009 at 11:01:44 AM | How the get back the model on the 3D tab.
Mulucae11
My model disappeared out of my 3D tab. can find it! been trying to find a tool but no luck! I turned on the box crop to find out where is the area of the model.
Muluc
Mon, Feb 2, 2009 at 11:13:00 AM | How the get back the model on the 3D tab.
try a ZA  zoom all
Mon, Feb 2, 2009 at 11:16:07 AM | How the get back the model on the 3D tab.
4 Stars: 205 Votes
Hi, did you import any CAD file to project???
Mon, Feb 2, 2009 at 11:33:42 AM | How the get back the model on the 3D tab.
Mulucae11
Yep, I did imported few CAD files to the project.
Muluc
Mon, Feb 2, 2009 at 11:54:21 AM | How the get back the model on the 3D tab.
What Typhoon is getting at is that your window may be very large because of the imported CAD file having things all over the place.  Because of that, your building might be a spec.  You could turn off the cad files in VG - then do a ZA and your building should now fill the window.
Mon, Feb 2, 2009 at 12:34:39 PM | How the get back the model on the 3D tab.
4 Stars: 205 Votes
That's right....
Mon, Feb 2, 2009 at 12:40:00 PM | How the get back the model on the 3D tab.
Mulucae11
I did try the VV and turn off the CAD, SkP and DFX files, But nothing, I even imported another mode;l to my 3D view and the other model didn't show up!
Muluc
Mon, Feb 2, 2009 at 12:58:41 PM | How the get back the model on the 3D tab.
4 Stars: 205 Votes
Ok, try this, in your 3D view, ZA then make a "crossing selection" and go to the "Filters" and see if there are elements in that view...
Mon, Feb 2, 2009 at 1:03:52 PM | How the get back the model on the 3D tab.
Did you make sure model elements were on and all linked or inserted cad files were turned off and then did a zoom all?
I'm sure you did not.... unless you are not telling us everything.  Do you have the right worksets on?  .... phases?
Another way ... while in 3d, find a family element in your browser that you know is in the model ... like a wall or door.  Right click on it in the browser and select all instances.  It will flag where these are.... and it will be a tiny spec somewhere on your screen - zoom that window area.
Mon, Feb 2, 2009 at 10:44:10 PM | How the get back the model on the 3D tab.
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
Click on VG and check all the worksets are on, also check all worksets are open from File menu>>Worsets. Click on VP and check which phase you are using.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Tue, Feb 3, 2009 at 4:20:28 AM | How the get back the model on the 3D tab.
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
Hey also check the section box is not checked in VP.
Pavan Reddy
Revit Manager
Tue, Feb 3, 2009 at 4:25:37 AM | How the get back the model on the 3D tab.
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
You can also delete the default 3D view in the project browser and click on the 3D button from the toolbar.
Pavan Reddy
Revit Manager
Model for back to back water closets
Wed, Jul 22, 2009 at 4:32:41 PM
Elevation Tab
Mon, Sep 19, 2016 at 10:13:48 AM
Can't Get Modify Schedules/Quantities tab to turn off - Revit 2014
Thu, Mar 30, 2017 at 1:15:02 PM
Revit to Ram and back
Fri, Jun 3, 2011 at 4:07:47 PM
Moving Design Options Elements Back To Main Model
Mon, Jun 15, 2015 at 1:57:58 PM
Page generation time: 0.6813
