Forums >> Revit Building >> Technical Support >> Multi page schedules
Mon, Feb 2, 2009 at 9:56:23 AM | Multi page schedules
davbrink
4 Stars: 1 Votes
Is there a way to have a schedule be split into two sheets? I am setting up cost modeling sheets for our estimating department. The problem arrised with the schedules getting to large to fit on one sheet (I.E. a wall schedule with all the walls scheduled seperately) If I can break it into two sheets I can set up one then if needed let it run on to a second.
Mon, Feb 2, 2009 at 10:47:16 AM | Multi page schedules
coreed
coreed Avatar
4 Stars: 16 Votes
you will have to set up some sort of shared parameter to filter your schedule by and create seperate schedules for each sheet.
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Jan 4, 2017 at 5:20:53 PM | Multi page schedules
archigrafix
5 Stars: 4 Votes
We have developed a plugin named Reports that generates multi-page documents from any Revit Schedule. IT support PDF, Word formats, and enables to print directly formated multi-page schedules to any printer. For more information check the features on the webpage.
http://www.archigrafix.com/reports-2017-perpetual.html
A free trial compatible with Revit versions 2014, 2015, 2016 and 2017 is available on the following page:
http://www.archigrafix.com/downloads
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Element Keynotes on Multi-Cat Schedules
Thu, Dec 28, 2023 at 10:07:15 AM
Export multiple Revit Schedules to multi-tab Excel file
Wed, Jun 2, 2010 at 5:09:12 PM
titleblock not lined up with page
Fri, Jan 13, 2006 at 1:32:44 PM
Multi-Category Schedule with Links
Wed, Aug 10, 2016 at 6:23:56 PM
Multi Discipline Border
Mon, Dec 7, 2009 at 1:49:57 PM
Page generation time: 0.7237
