Forums >> Revit Building >> Technical Support >> L shaped column
Sun, Feb 1, 2009 at 4:31:30 PM | L shaped column
morrisaltis
Hi
I've created an L shaped parametric column in Revit 2009. The column wont cut in plan view - the top of the column shows. Does anyone know if i can cut this column? The family is attached.
Sun, Feb 1, 2009 at 4:34:25 PM | L shaped column
coreed
coreed Avatar
4 Stars: 16 Votes
i see no family attached
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sun, Feb 1, 2009 at 4:45:36 PM | L shaped column
morrisaltis
Sorry people the file did not attach. Here it is.
Mon, Jun 22, 2015 at 4:37:29 AM | L shaped column
immiraj
hi there
i saw your family.
first thing u took wrong family type. you used Framing Family instade of Structure Column.
and use Cut Pattern and Surface Pattern in your Material.
Why is my hollow column doing this in plan?
Wed, Apr 4, 2012 at 11:06:10 AM
Problem with U-shaped stairs
Tue, Jul 9, 2013 at 8:10:56 AM
To create an egg-shaped mass?
Mon, Aug 27, 2012 at 5:16:05 PM
Round stair landing with a U shaped stair
Mon, Sep 12, 2011 at 4:41:16 PM
customerized curtain panel doesn't work with the irreglar shaped panel?
Sat, Jul 10, 2010 at 1:48:42 PM
Page generation time: 2.0019
