Forums >> Revit Building >> Technical Support >> Overhead doors in schedules
Fri, Jan 30, 2009 at 1:03:03 PM | Overhead doors in schedules
davbrink
4 Stars: 1 Votes
I am working on a service garage  with several overhead doors. The doors come into the schedule but the "To Room: Name" or "From Room: Name"  are not available the doors are clearly in a space but I can not get that information. I can not even write in to info since it is a pulldown.  Any help would be appreciated.
Fri, Jan 30, 2009 at 1:22:26 PM | Overhead doors in schedules
BDerrick
3.5 Stars: 3 Votes
Hi davbrink, I think I can help.
When you create the door schedule.  You need to create your own parameters.  In the 'Fields' pull down of the 'Schedule Properties' click on 'Add Parameter'.  Name it 'From Room', put the parameter group on 'Identity Data' (or your choice), make sure that the Parameter Type is set to 'Text' and also make sure that you check the 'Instance' box.  Repeat the process for the 'To Room' parameter.  Add any other information you need in your schedule.  The problem with this method is that the doors won't fill these parameters on their own.  Click on any door and go to its element properties.  You should be able to fill in the 'To Room' and 'From Room' parameters manually.  The rooms should appear on the schedule.
I'd be interested to hear if there was an automatic method.  Let me know if you figure something out.  If not, I hope this way works for you.
Fri, Jan 30, 2009 at 1:34:22 PM | Overhead doors in schedules
tim123
4 Stars: 19 Votes
Go to a section view and make sure that the room upper boundary is high enough to include the door.  It should then schedule.
Fri, Jan 30, 2009 at 2:02:34 PM | Overhead doors in schedules
davbrink
4 Stars: 1 Votes
That was the problem the doors were 16' hi and the space was still set at 9'.   Thanks for the help.
Rolling Overhead doors in Schedule
Thu, Dec 23, 2010 at 6:57:39 PM
overhead lines
Tue, Jun 3, 2008 at 5:23:47 PM
Cutting of Overhead Doors
Sun, Jun 16, 2013 at 11:45:18 AM
dOORS AND DOOR SCHEDULES
Mon, Aug 6, 2007 at 11:28:15 AM
Overhead Lintel - Doors and Windows
Wed, Mar 22, 2006 at 4:23:48 PM
Page generation time: 0.5237
