Forums >> General Discussion >> Wishlist >> Need plywood panel
Fri, Jan 30, 2009 at 11:03:42 AM | Need plywood panel
SofiaClark
I need a plywood panel detail component, not a section.  Anyone have one?
Tue, Feb 10, 2009 at 6:44:59 PM | Need plywood panel
robinballew
robinballew Avatar
3 Stars: 4 Votes
So you need a rectangle? Detail Components are just 2d. Do you mean a 3D Plywood element?
BallewDesigns.com
Sun, Dec 6, 2009 at 9:36:07 PM | Need plywood panel
SofiaClark
Yes, just a 2D rectangle would work fine.
Mon, Dec 7, 2009 at 7:06:06 AM | Need plywood panel
I think robin is suggesting you do a simple fill using your rectangle line tool and a plywood model pattern.
Mon, Dec 7, 2009 at 11:47:25 AM | Need plywood panel
SofiaClark
That will work.  Also looking for a WT column.  Thanks.
Custom Rafter Cut for plumb plywood and square standing seam
Sun, Dec 15, 2013 at 10:26:27 AM
plywood
Sat, Feb 12, 2005 at 5:01:50 PM
4' x 8' plywood representatiion in Revit (3d view)
Wed, Feb 10, 2010 at 7:42:33 AM
vertical plywood
Fri, Nov 25, 2011 at 8:26:44 AM
12
Plywood under wall
Wed, Sep 3, 2008 at 7:39:52 AM
Page generation time: 2.1003
