Forums >> Revit Building >> Technical Support >> Cost Modelling Schedule
Thu, Jan 29, 2009 at 5:47:52 PM | Cost Modelling Schedule
davbrink
4 Stars: 1 Votes
I trying to put together a preliminary costing schedule by taking our wall types and assigning them a cost per linear foot. In the wall properties you can assign a cost to the wall. In the schedule I was creating a wall schedule that had all the walls of the project listed. I am trying to add a calculated value to the fields with the formula reading "Cost*Length".  You would think that would be an easy formula. But they reject it becuase it has "inconsistant units" and will not let me create the field.   I can not change the units on either of them.  So how do I work around this stupid little problem.
Fri, Jan 30, 2009 at 6:09:40 AM | Cost Modelling Schedule
tim123
4 Stars: 19 Votes
As Revit suggests, the units are inconsistent.  Length * number = length, so the units need to be set to length, not number for this to work.
Fri, Jan 30, 2009 at 9:49:51 AM | Cost Modelling Schedule
davbrink
4 Stars: 1 Votes
It seams rather limiting for the programmers to limit formulas to the same "units". So is there a way to make the totals unitless so I do not have to read cost per foot in feet and inches.  My grand totals came out to be 60737'-2 13/32"
Fri, Jan 30, 2009 at 10:05:09 AM | Cost Modelling Schedule
tim123
4 Stars: 19 Votes
Under formatting go to Field Format and override the project settings.
Calculating two Formulas on the same row in a Schedule
Fri, Dec 17, 2010 at 7:22:56 AM
Area Schedule Estimated Cost
Fri, Aug 21, 2009 at 10:09:35 AM
Material Cost Analysis in Schedules
Wed, Jan 13, 2010 at 6:55:37 PM
Material cost per sq ft formula
Mon, Sep 21, 2009 at 9:06:24 AM
preliminary cost estimates
Sat, Feb 27, 2010 at 7:24:14 PM
Page generation time: 0.2698
