Forums >> Revit Building >> Technical Support >> dwf with 2d cad information
Thu, Jan 29, 2009 at 2:03:29 PM | dwf with 2d cad information
diesellam
Is there a way when you export to a dwf file from Revit 2009 Architecture with the 2d CAD info such as grid line and gird bubbles?  The grid line file is currently linked to the Revit file.  But after export it to dwf, it dissappears, is there a way to make it show up?
Thanks in advance.
Thu, Jan 29, 2009 at 2:14:46 PM | dwf with 2d cad information
4 Stars: 205 Votes
Did you try it????
Thu, Jan 29, 2009 at 3:09:58 PM | dwf with 2d cad information
diesellam
Sorry for the confusion, I meant 3d dwf, not 2d dwf.
I was hoping the grid will be imported in the 3d dwf file, is that doable?  Thanks.
Thu, Jan 29, 2009 at 3:18:37 PM | dwf with 2d cad information
4 Stars: 205 Votes
Like you must already check, if you put the grid lines ONLY appears in Plan views and Elevation views perpendicular to that view, don't appear in 3D view, so you CAN'T create a 3D View with grid lines, even thought, if you try to create a 3D DWF, Revit tells you "3D DWF Files Only Export from 3D View"...
Thu, Jan 29, 2009 at 3:56:10 PM | dwf with 2d cad information
diesellam
I think it would be cool when you orbit the 3d model around and still can see grid line as a reference in 3d.
Thu, Jan 29, 2009 at 4:22:13 PM | dwf with 2d cad information
Lines are lines .... obvious they will not show as 3d elements.  If you really want them in 3D, they need to be planes and baybe you want to add some  in-place glass plane families to represent a 3D grid ... of couuse if you really want to mess it up, you could add some glass planes at the floor lines to represent your levels.
But, for what good it is, if you want to see then flat on one of the levels.... like 1st floor, export your grids to CAD and re-import them.... they will the be 3d lines on a flat plane and that will export to dwf.
Thu, Jan 29, 2009 at 5:54:07 PM | dwf with 2d cad information
diesellam
So you mean to export the revit file that already has the grid lines in it to another dwg file, and that open up that dwg file in AutoCAD and then import/link this dwg file back to the revit file??
I've tried that and it didn't seem to work.
Also another thing, inside the dwf file, when I tried the View > Cross Section, it's very cool to generate those sections instantly.  But my question is how do you switch back to show the entire thing of the dwf file after generating these cross sections?
Thanks in advance.
Fri, Jan 30, 2009 at 7:33:54 AM | dwf with 2d cad information
You must be doing something wrong.  Attached is a 3D image showing part of a building and a 2D site plan inserted at 2 different levels.  Works the same for a plan that just has a column grid.
Fri, Jan 30, 2009 at 10:14:45 AM | dwf with 2d cad information
diesellam
Please see the attached PDF file.  Am I missing some steps here?  Thanks.
Fri, Jan 30, 2009 at 10:49:50 AM | dwf with 2d cad information
I must apologize ...  I knew that the 2d worked in 3D revit.  I did not realized it would not work in 3D dwf.
DWF
Tue, Mar 27, 2007 at 10:19:52 AM
DWF Linking
Thu, Aug 23, 2007 at 12:55:32 PM
Revit views to DWF format to print
Fri, Mar 19, 2010 at 12:21:41 PM
help! dwf for 2d plans
Sun, Feb 26, 2006 at 8:15:57 PM
Can anyone help me understand DWF's in Revit...Please?
Wed, Jun 21, 2006 at 1:22:46 PM
Page generation time: 0.3487
