Forums >> Revit Building >> Technical Support >> walkthrough questions
Wed, Jan 28, 2009 at 7:02:05 PM | walkthrough questions
diesellam
What's the typical reasonable frame/second setting for a 1 minute walkthrough animation?
For the door in Revit, is there a way I can make it open in the walkthrough instead of feeling like crashing into the door?
Thu, Jan 29, 2009 at 4:14:56 AM | walkthrough questions
4 Stars: 205 Votes
30 Frames per Second x 60 seconds= 1800 frames but if I was you I use MAX to that because it's more quick and you can control the opening of the door along the "Path" of the movie....
Thu, Jan 29, 2009 at 9:08:05 AM | walkthrough questions
erland73
erland73 Avatar
4.5 Stars: 85 Votes
I agree with Typhoon, 3ds Max is faster than Revit for walkthrough scenes....
Thu, Jan 29, 2009 at 12:59:21 PM | walkthrough questions
diesellam
Thanks for the suggestion.  Will try it in Max2009.
Thu, Apr 23, 2009 at 10:56:51 PM | walkthrough questions
echo1
I created an instance peramiter in my doors to torn off the door panel.  Since doors usually swing to the most out of the way position, it fools the casual observer.
Fri, Apr 24, 2009 at 7:34:54 AM | walkthrough questions
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Are you talking a rendered walkthrough or hidden line/shaded?
30fps is overkill.  15-20 is sufficient for smooth motion.  Depending on your resolution and if this is rendered, you may be talking 5 minutes to render each frame in Revit at least.  Which equates to 1 hour 15 minutes.  If they are internal renderings though this can very quickly bloat out...
It's also a good idea to export individual frames and compile the jpg images as an avi post process.  This way you could edit the frames with doors (with a customised door family that can have a 3D door swing) and have them actually open and close...
HTH.
Regards,
Chris.
Sun, May 10, 2009 at 7:46:13 PM | walkthrough questions
Tim130
Hey, I know this was an old thread, however I'm looking at making a walk through, I have directed the arrows are have made the video/walkthrough, however can the walkthough be rendered, I.e the trees in the walkthrough are just gray, or does this have to be done on 3ds max??
Sun, May 10, 2009 at 7:49:41 PM | walkthrough questions
Tim130
i've jsut seen this thread....
http://www.revitcity.com/forums.php?action=viewthread&thread_id=3899
Mon, Mar 25, 2013 at 2:44:09 PM
Exporting Walkthrough Trouble
Thu, Apr 17, 2008 at 8:00:50 AM
New to revit and have a question... Re: walkthrough on 2011
Tue, Apr 12, 2011 at 6:01:12 PM
walkthrough
Wed, Aug 1, 2012 at 5:43:43 PM
Walkthrough
Thu, Sep 24, 2009 at 8:24:31 AM
Page generation time: 3.3860
