21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Placing filled regions for tiling in bathrooms
6 Posts No Rating |
Is there a quick technique for placing a filled region for tiling on a bathroom floor without having to cut around fixtures?
if your fixtures are 3d they should cut, if not, attached a filled region to your family.
I normaly have my sub floor (say 200mm concrete) and on top I'll have my finished floor with the surface pattern of tiles or what ever it is.
m2c
6 Posts No Rating |
We're using the technique of the tile floor, but I didn't know it was possible to place a filled region in a family. How do you do that?
The fixtures you are using are only using 2D linework to represent them in plans. Edit the family and turn on the 3D model so it is visible in plan.
If this has too much information, embed a detail component into the family that contains a filled region to the extent of the fixture.
HTH.
Masking Regions and Filled Regions BEHIND 3D Objects |
Wed, Aug 1, 2012 at 8:10:27 AM
Filled Regions and families |
Sun, Mar 8, 2009 at 7:10:29 PM
Filled Regions on an elevation |
Wed, May 25, 2005 at 1:35:38 PM
Revit 2014 Filled Regions |
Fri, Jun 27, 2014 at 4:47:56 PM
11
Masking Regions and Filled Regions - Which Is In Front? |
Fri, Oct 28, 2011 at 2:26:55 PM
