Forums >> Revit Building >> Technical Support >> ALL Revit text sizing is INCORRECT!?
Tue, Jan 27, 2009 at 12:39:18 PM | ALL Revit text sizing is INCORRECT!?
sembrede
We have been using revit for several projects now but just noticed that our text sizes are off by a small margin.  Typically we use 3/32" but recently discovered that in order to have a plotted sheet with text at 3/32", we must set the revit text to 7/64".  All the sizes seem to be off by this similar percentage.
Is there some overall scaling tool we don't know about or is this a Revit glitch?  It is very easy to overlook. We only discovered it because we had imported a CAD detail and placed it next to Revit text on a sheet.  The CAD text size is slightly bigger (and accurate) even though our Revit text was set to the same size.
It is easy to fix but driving us a little crazy!  Seems text size should be something a program like this could do accurately Winking
Tue, Jan 27, 2009 at 12:40:40 PM | ALL Revit text sizing is INCORRECT!?
sembrede
Oops, forgot to mention we are using Revit 2009.
Tue, Jan 27, 2009 at 3:12:21 PM | ALL Revit text sizing is INCORRECT!?
sembrede
I also want to add that I just checked the generic template (thinking it could be a problem embedded in our office template) and found the same problems.
You could check it yourself... print out a 3/32" and a 7/64" test and scale them.  Please let me know if yours is the same way!
Tue, Jan 27, 2009 at 3:38:07 PM | ALL Revit text sizing is INCORRECT!?
sembrede
Ok so after more investigation, I found that it is our font, architext, that is scaling wrong.  I put both architext and arial at 3/32 and 7/64 into revit, exported to autocad and guess which program is smart enough to figure it out.... CAD!  So the autocad file knows that architext at "3/32" is actually 5/64.  Any suggestions?  Should we just find a different font?
Tue, Jan 27, 2009 at 5:39:05 PM | ALL Revit text sizing is INCORRECT!?
mrmoo
mrmoo Avatar
2 Stars: 1 Votes
If your work around isn't adequate, then that might be your best option.  But if you just need it to print properly, and there aren't any import / export issues, then stick with the 7/64" architext.
TEXT OVER SIZING;
Tue, Apr 18, 2017 at 12:09:21 PM
Pipe sizing in Revit.
Tue, May 6, 2014 at 7:00:56 AM
Revit 2013 - MCWS Pipe sizing
Wed, Jan 23, 2013 at 10:29:46 AM
Text formatting (bullets & indents)
Wed, Jun 11, 2008 at 8:49:15 PM
Stair Handrail Extension - Incorrect Height
Tue, Mar 14, 2017 at 3:41:27 PM
Page generation time: 3.3832
